Apps Buttons only work after first button is pressed
ktUK
I have an xml page with 3 buttons on all leading to similar xml files. However, the second and third buttons only respond if the first has been pressed (and then you go back a page and press another). If I reverse the order of the buttons in the java file, which ever button is listed first is the one that has to be used befor the others.
Here is my java for the buttons:
________________________________________________________
package converter.units.kitchen;
import android.app.Activity;
import android.content.Intent;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
public class Menu2 extends Activity {
@Override
// TODO Auto-generated method stub
setContentView(R.layout.convertmenu);
Button start = (Button) findViewById(R.id.buttonLitres);
start.setOnClickListener(new View.OnClickListener() {
public void onClick(View v) {
startActivity(new Intent("android.intent.action.CONVERTLITRES"));
Button start = (Button) findViewById(R.id.buttonGrams);
startActivity(new Intent("android.intent.action.CONVERTGRAMS"));
Button start = (Button) findViewById(R.id.buttonOunces);
startActivity(new Intent("android.intent.action.CONVERTOUNCES"));
Any help would be greatly appreciated, the rest of the app has no errors and functions correctly. Thank you very much
This is happening because you are instantiating the second and third button inside the onClick method of the first button. Close the first onClick method and do the same to the second and third button
