knowLittle
Hello All,
I know that this post is very old, but I have a similar question. I believe that it is very relevant and there should be copious material on the net, but I have been unable to find it.
I am trying to port a C++ project into Android. My project uses NTL, GMP, and OpenSSL. I am able to compile this libraries using instructions on the net, but I wonder how to go about calling the code in the project.
I have seen examples that individually call a function from a library in C++. So, this function would be wrapped in JAVA JNI form.
I highly doubt that this is the way to go in porting a huge project with many lines of code in many different files and different function calls.
Any one can help?
Thank you.
Any one can help?
Thank you.
