Help Cable tether
boydn1
I started this in the anything root and don't think that's where I need to be.
I have a Evo 3D and a Motorola Xoom. Trying to cable tether and can't figure out what cable I need. It looks like I need a "Micro B" to "Micro B" and can't seem to find one.
Any ideas on what I need to do this?
Thanks
moved your post here.
search here for "tether" and you will get some hits.
why not use BT tether? do you HAVE to use a wired solution?
im also ASSuming you are rooted yes?
EDIT: im not sure if you can use a wired connection. i think you can only do it WIFI or BT?
