calc on lockscreen? wtf
wolfdogg
Member
i have a sch-1515 Nexus Toro, i modded it with aokp_toro_jb-mr1_milestone-2.zip, and i cant figure out how to get the calculator off the lockscreen, and or where it came from. i already went into rom custom lockscreen settings and toggled on and off the widget settings. I see a calc, then when i move the lock, the calc shrinks to the size of a 4x2 clock widget, making me wonder if its a broken clock widget, or did i miss a setting somewhere?
Also, i made a custom picture for the lock, and although i see it on the test screen "only" after sliding the lock, i dont see it at all on actual the lock screen, i just see the default padlock.
another problem is i set a custom led color , and one would suspect that the LED would be that color, but only at random times is it actually that color, otherwise its red, or yellow, which is not the color i set it to be.
Is that rom bugged?
