Help Calendar force closes
Hi All,
I have a rooted Droid 2 Global. It works like a charm now that it's rooted and that I froze all the useless stock apps with bloat freeze.
My problem is that my calendar force closes as soon as I try to add an event. This is probably a permission problem. I tried fixing my permissions with ROM Manager and with Fix Permissions. I restart the device after I fix the permissions, but it still force closes.
Fix Permissions doesn't have the calendar in the listed applications, so there is the problem with that one. But I still tried ROM Manager...
Does anybody know what's going on?
Thanks
