Calendar Intermittent
Jim255
I have a Galaxy Note 2 and have been using S-Planner for many months with no problem. I have a whole bunch of calendars (about 15) which sync.
Suddenly a couple of weeks ago, I went into S-Planner and it was blank - no entries in any days at all. A reboot sorted it out, but now this is happening once or twice a day.
I have loaded the official Google calendar app, and this seemed to be stable but I don't like the views.
I have also loaded aCalendar (which is excellent, and well worth paying for Pro). This does the same as the S-Planner though.
I have also tried uninstalling all calendars, turning off calendar sync and clearing all cache then reloading and turning sync back on, and this has not cured the issue.
I think that a factory reset will probably cure it as I had no issues for many months until a few weeks back, but this seems a bit severe for this minor issue.
Any other ideas?
Cheers.
