Help Calendar issues.
NormanHG
Hi,
Not sure if this is an IOS or an Android issue- however...
Just started using Android with an S3, and already have, and wish to keep, an iphone.I have Google calendar on the S3 and CalenMob on the iphone. As far as I can tell, all the right accounts are set up both phones. If I make an entry in the S3 calendar, it appears in the iphone one. But it doesnt work the other way. Any ideas?
Thanks
Norman
Welcome to the forums!
Make sure when you're making a calendar entry in iOS, that you select a calendar that syncs between your devices (probably gmail)
