Help Calendar probs
Holm100
Hi all
I'm somewhat new to the use of this Google calendar. I've gotten my phone calendar to sync just fine with my online google calendar, but...
My GF is sharing her goolge calendar with me, and it shows up just fine online, but NOT on my phone calendar. My gf's calendar doesn't even show up on the "list of calendars" on my phone.
Is there any way for me to see the shared calendar on my phone calendar, or am I trying to do something that can't be done?
My phone is a Samsung Galaxy 3
Kind regards
B.
Hey,
Make sure you both have the ability to edit each others calender im pretty sure it has to be both ways (if its not already)
Hmm, still doesn't work and I've got full access to her calendar now.
It shows up just fine on the online calendar, now under "My Calendars", but I can't get it to show up on my android.
Any ideas are wellcome :)
B.
Hi all
Kind regards
B.
On your smart phone do the following:
  1. click the calendar icon
  2. click menu
  3. click more
  4. click calendars
You should see a list of calendars, scroll down to your GF calendar. Verify that your GFs calendar is checked. If not, check it, you should then be able to see that calendar on your smart device.
