Help Calendar - repeating event issue
Here's an issue I found with my new S3. If you create an event in your calendar, you cannot create one that repeats annually without the app force closing. My workaround is that I just go in on the computer on gmail calendar and change the appointment to be annual repeating. You can make any other repeating event but the annual does not work for some reason. I reported the issue to TMobile and Samsung. A master reset does not fix this issue. Supposedly, this will be addressed in a future update.
I found this same bug and posted about it last week. Thanks for reporting it and posting a workaround, although I don't use Gmail calendar. I figured it would probably get fixed in the jb update.
I must have missed your post. Oops! Luckily, it isn't that bad of a bug. It only impacts events that repeat annually. Every other type of repeating event works. :)
