Hey all-
Have had a MyTouch 4g for a few weeks now. Having occasional trouble with my calendar syncing. It will try to sync far too often (every 1-5 minutes, sometimes getting stuck while syncing) subsequently draining the battery. Google Calendar should be syncing with push, so there's no good reason for in to be syncing every 3 minutes, right?
Often the sync wheel won't be spinning in the notification bar, but when I go into setting, and check out sync settings, I find out that it is trying to sync. Usually every minute. Or every few minutes. Also often it will be trying to sync for a few minutes (it should not take a few minutes for a simple calendar sync). Also, sometimes when I look at the sync wheel (under settings - sync accounts) the wheel will be present, but not spinning, with the "last sync" time a few minutes ago - to me, that looks like it's locking up trying to sync.
This problem doesn't happen all the time. I'll often check when my last calendar sync was, and it'll be hours ago, with is all great. When this has happened before, it has been solved by a simple reboot, or force close Calendar. I've been having the problem all day today, and it's draining my battery. Causing me to be quite unhappy!
Has anybody had this happen? Any ideas or solutions? Seems like it could potentially be a problem with google sync server??
Thanks.
Thanks.
