Help Calendar Sync Problems
MerpsMom
Member
I've tried a lot of things but I can't get my Galaxy Epic Touch calendar and Google's on my computer to stay stable. Shouldn't an event show up on both calendars no matter from which I entered it?
I've gotten if "fixed" and then it goes back to being unstable. I've gone into the phone's Accounts and Sync, done all that, and refreshed the computer's Google calendar. Nothing really stays in place.
Help?
MM
Yes they should - I have not had any problems with my gmail calendar and the stock calendar.
Have you "removed" the gmail account and then added it back in? If not, I would remove the account; remove battery for about minute then reboot - then readd the gmail account and sync. The other thing is to open up the stock calendar, go to menu/settings/touch "calendars" at the top and make sure your calendars are all checked; also see which one is default calendar (I have my gmail as default - not sure if that makes a difference).
