I don't think it's an android thing but.....
I've been looking for an answer and so far nothing. Apparently Google used to sync Outlook and Google calendar, but now stopped that. I asked Motorola and they thought the calendar from Outlook should sync to all past dates on the phone. But since it is also happening on my Samsung Note, probably not device dependent. SO, is there reliable way to sync Outlook entries to Google calendar entries? And would the Google Calendar entries then go back years then on the devices?
That looks like an interesting solution. Unfortunately, I suspect it will be subscription only. I probably don't need old dates on my phone that bad. But it does seem odd that if I had a birthday listed in June to remember, it wouldn't show up on the phone at this point, or perhaps, until I pay for an app to do that.
I am not sure what you mean. Doesn't Google calendar sync with Android phones? Or do they do have issues with going back more than a year?
