Dem
This is really starting to get my noodle.
At work, we use Lotus Notes. This has all my work Calender appointments.
Unfortunately, Google sync will only work with Outlook. So, I bought a piece of software for my work PC which will transfer Lotus Notes Calender into Outlook on my PC. That works great. However, Google sync doesn't! It seems to have transferred some old, deleted entries to my Google Calender (including the phone).
I guess the problem is the Google Sync software on the PC. Anybody encountered anything similar?
I'd like to clear my Google Calender (on PC and phone), but can't find a way to do that other than by deleting each entry individually, which I don't fancy!
Any help appreciated.
Thanks,
Dem.
PS: IT department at work are trying out something called "MyLink", which is separate software on the PC and phone to get the Lotus Notes Calender on the X10. However, I'd prefer to get it into my Google calendar if possible.
Thanks,
Dem.
