Help Calender Question??
rachael:)
Hi,
Need help with new phone....
Can't get the calender to work, when I try to add an event it tells me I have no calender?? I have tried to download a current calender and it still does not work....
Can anyone out there explain how to get this to work :confused:
Thanks,
Rachael
Hi,
Thanks,
Rachael
Hi :)
I had the same problem with my new Ideos,so downloaded a calendar "simple calendar Free" by bmjones2 and it fixed the problem..
I hope this works for you
Hi,
Thanks,
Rachael
Assuming you have a gmail account this is what happens in my phone.
Start the calender app. press Menu, select Calenders. Now you should see a list with at least your gmail calender. Touch the selection to toggle between the following:
-synced, visible
-synced, not visible
-not synced, not visible
Choose synced, visible
Now your events will be saved and displayed and synced with your gmail account. Good luck.
-synced, visible
I have a gmail account but when I got to 'Calenders' in the Menu section none of my calenders are listed. How can I make them appear?
