Calenders missing
rcyphermd
Android Expert
I have the Galaxy note 2. Two of my calenders are on my laptop, but not on my phone. I have it checked to be there. Suggestions?
How are you syncing them?
If Google, can you see them with Google calendar via a web browser? Then check the calendar display options in your phone's calendar app - see whether they are there but not being displayed.
If your calendars are Gmail-based or Hotmail-based then:
1) Add those accounts to your phone.
2) From your home screen hit Settings button -> "Accounts & sync". Make sure that Background data and Auto-sync are checked.
3) Click on each account and check "Sync Calendar".
4) From within the Android calendar app on your phone., hit Settings -> More -> Calendars and then click the synchronization and eyeball symbols next to each calendar to make sure that they are synced and visible.
Thanks for trying. I have done all those things and it is not syncing NHL hockey calendar. It did before the last Verizon update
