Manual says to dial *720 then press "Call" will disable call forwarding and should let the call go to your voicemail.
Last one I can think of to try is *38
No problem. One is conditional forwarding and one is non conditional forwarding from what I can figure out... if one doesn't work, the other usually will.![]()
