Help call log multiple entries
Hi
Ace's default "phone" app displays multiple entries in the log section....
i mean it doesn't combine entries of the same contact.... if i call sam 5 times i see 5 entries in the call log, and an entry for every text send/received which is annoying.
i tried Go contact/ Go dialer which does the job but uses more memory.....
what dialer/log app you guys are using ?
can i uninstall default "phone" app using root uninstaller (is it safe, or ace might crash ?)
same thing with default messaging app, i use Go SMS, so can i uninstall "messaging" app ?
