Call Management has stopped
  • Thread starter Thread starter RVFmal
  • Start date Start date
R
RVFmal
Guest
Is anyone else experiencing the error Call Management has stopped when making or receiving a call? I have tried clearing all the caches and data from the call related apps to no avail. Effectively, the phone can not be used as a phone.
Model Number LG-H850
Android v 8.0.0
Kernel Version 3.18.71
Build Number OPR1.170623.032
Software Version V30h-ZAF-XX
maybe do a factory reset. it should fix it. if it does not, then contact your carrier or wherever you bought the phone to see if it can be fixed or replaced.
