Help Call Recording problem in i5801
avaru_123
Hi,
My handset is unable to record my outgoing call without loud speaker option, i used vrecorder, auto call recorder, but the status is same. Please suggest me the application which can record normally with out any automatic loud speaker option.
Note:- If I turn off loud speaker i cant heat the voice through handset speaker.
appreciation for ASAP quick response ..
THN Q
VK
Hello,
samsung android mobiles have a drawback that it wont allow call recording at all even if it is working with you when u switch on ur loud speaker it means the recording is getting done through mic but not the voice directly. If at all you need an automatic call recorder app, i have developed it. but only for the android phones other than samsung and has sd card support
you can also contact me through my mail id balaji.march31@gmail.com
Regards,
Balaji
Hi,
THN Q
VK
Hi VK,
Are you able to record two way communication ( both your voice and receiver's voice) with loud speaker on in samsung I5801?
Regards,
Thirumal
