Call Reject after xx Seconds
bonky
Hi All
Im after a program that rejects all or a select calls after xx amount of rings/secs of ringing. with a log of those rejected calls.
Baiscally the same as swiping to reject the call... but in a program form
Pref upto 90secs Max ...
Do you know of a program that does this... or is there anyone that can devlop one?
Thank you in advance
I don't think there is a API which allow app to reject a call. The most we have is missed calls. For apps that claim to do so, most likely they use un-documented API. Thinking back, it is a good thing no API exist else imagine a developer write an app that keep rejecting legitimate calls! It is as if the app hold the smartphone ransom hostage!
