Heroine
Member
Hi,
Anyone know if there is there a method to quickly withhold your number for outgoing calls as and when neccessary? Currently I do it via home/menu/settings/call settings/additional call settings/caller ID *phew*
Ideally I would like to be able to toggle caller ID on/off from one of the homescreens..is that possible?
Thanks
Thanks
Explained that doesn't work from my handset and they said only other option is the long winded version I am currently using. Would be interested to know if 141 works for anyone else using TM if anyone feels like checking it out.
