Apologies if this has been dealt with before - searches did not pop anything obvious.
I'm looking for an app that integrates calling card dialing (i.e. access number and pin) with contacts. Something where I can easily search for a contact as normal and then choose to direct call or call via the calling card.
Calling Card Pal is great, but only for international calls.
https://play.google.com/store/apps/details?id=com.netspectrum.ccpal
It has no ability to distinguish national long distance in Canada (9 digits) from local 9 digit calling. I need something that either can memorize whether or not to use a calling card for a specific number, or always give me the choice. There are several apps out there that do this, but none that I found that integrate with contacts so calls can be made without opening the calling card app.
Have I missed one that does this integration?
Thanks!
Sasmung Galaxy S3
Thanks!
Sasmung Galaxy S3
