Help calling from contacts
  • Start date Start date
A
Android Question
Guest
All the sudden when I try and make a call from my contacts I get a message that says, There is no internet calling accounts on this phone. Add one now? Then there is a choice of cancel or add. If I "add" another message comes up that says Receive incoming calls and a box to check. If I check the box it still does not allow me to make a call directly from the contact. I am able to dial the number, just can't call from the name itself. Help! I have hundreds of contacts. I am a real estate agent and it is very time consuming, to look up the name, write the number down and the dial it to make a call.
Did you uninstall the dialer?
Sounds like your using the contacts app to make a call.
You need to use the dialer app to call with, which works in conjunction with your contacts
