Help cam is not recording!! plzz help
DrSadir
hi am new to android
i have a problem when i open camera and start to record video
a message appears says "recording failed"
plz i need ur help
i think the problem is in the mic or voice because the voice recorder is nt workin, voice search is nt workin and even talking tom is nt workin also
plzz any help
Do you have the official Twitter app installed? If so uninstall it. It's worked across the board in many forums and online help, and also worked for me. My phone also would not play youtube vids either and getting rid of twittter has also fixed that.
Hope this helps :)
my galaxy sl gt the same problems too... the voice recorder, capturing video with voice (both will force close) and voice search not working... sent it to the service center and the person there told me that it is the problem with the software corrupted causing those voice recording function to fail. But after reformatting the android software, the problems still there.. so they ended up changing the phone's motherboard. luckily its still under warranty period. Btw, i nvr installed twitter.
