Unforgiven83
After going over to velocity 1.0 on my wifes phone every time the camera button is pushed it reboots the phone.
Is there a fix for this?
It is a stability problem you need to underclock before using the camera. No real fix for it other than that right now the little device just simply cant handle it but using frunishers kernel helped stability alot but still every once and a while the camera reboots on me to. You can also try turning off stagefright and see if that helps.
I'm OC'd at 787, and my camera works just fine...
I have to underclock.gotta remember not all allies have the same quality cpu some can clock higher some lower some stable some shaky.I'm OC'd at 787, and my camera works just fine...
