camera error
  • Thread starter Thread starter mohamed
  • Start date Start date
M
mohamed
Guest
I have a problem my camera is not working that problem message is camera failed messagehandler.handlermessage (-1) how to correct that? phone model is samsung y pro dous
gt b-5512.
There's a thread over at the XDA-Developers forum that discusses that exact problem with a few proposed solutions. Maybe one of them will work for you.
  1. Try a different camera application. Camera360 is a popular choice.
  2. Wipe your cache partition. This video is specifically for the Galaxy S, but I believe the technique should be the same.
  3. A Factory Reset may be necessary. Note that this will cause you to lose your data.
  4. Lastly, it could be a hardware issue - in which case you'll need to consider contacting a repair shop or replacing the phone.
Hope this helps.
