I have an android application which contains multiple activities.
In one of them I'm using a button which will call the device camera :
In the same activity I call the OnActivityResult method for the image result :
The problem is that the intent data is null and the OnActivityResult method turns directly to the (resultCode == RESULT_CANCELED) and the application returns to the previous avtivity.
How can I fix this issue and after calling the camera, the application returns to the current activity which contains an ImageView which will contains the picture taken?
Thanks
Code:
public void onClick(View view) {
Intent photoIntent = new Intent(MediaStore.ACTION_IMAGE_CAPTURE);
startActivityForResult(photoIntent, IMAGE_CAPTURE);
Code:
@Override
protected void onActivityResult(int requestCode, int resultCode, Intent data) {
if (requestCode == IMAGE_CAPTURE) {
if (resultCode == RESULT_OK) {
Bitmap image = (Bitmap) data.getExtras().get("data");
ImageView imageview = (ImageView) findViewById(R.id.pic);
imageview.setImageBitmap(image);}
else if (resultCode == RESULT_CANCELED)
{Toast.makeText(this, "CANCELED ", Toast.LENGTH_LONG).show();}
Thanks
