Root Camera issue in CM7 leading to problem with barcodes
Modman
Constantly have to reboot cause camera constantly stops working.
On top of that shopsavy Keeps sayiing it can't connect to the camera.
On the stock os it it worked. Is there a fix?
No. That's been a known problem since day one. But there is a trick. Take a picture of the bar code go into your gallery and select share and then the bar code app
As stated before no camera apps works with cm7...
What app are you using? Gallery won't send to barcode scanner or shop savy. If I send a bar code picture with root explorer both programs tell me my bar code is invalid. The barcode programs are not an option to send too in gallery.However I can send pictures with Google goggles.
