Help Camera Issues
Every time I try to bring up the camera by clicking on it, the screen goes black and nothing happens. I can take pics with the button on the side of the phone, but I have to go to my gallery to see them. I am thinking that it could be one of my apps and I will have to restore back to phone defaults, but figured that I would throw it out there before I lost any time.
It's been documented in a few places now that any app or widget that adjusts the brightness can cause this issue. Try going into your settings and checking/unchecking "auto-brightness" and then try the camera.
my brother had a similiar issue, he went to the sprint store they did a hard reset and all is fine now
I got my moment last Wed and the camera and camcorder are no longer working at all. I can snap a pic and it takes it but it goes no where not even in my gallary. The camcorder won't even come on it just says cannot turn on camera module. I took it to the service center and they did a hard reset but nothing happened. They have now ordered me a new phone to replace mine.
That sucks since all you have to do is what agent0014 suggested. It worked for me. Camera works fine again! So...
"It's been documented in a few places now that any app or widget that adjusts the brightness can cause this issue. Try going into your settings and checking/unchecking "auto-brightness" and then try the camera."
The problem is probally you have a program/widget for controlling screen brightness if you do with widget bring the brightness down to 0% then uninstall the brightness app/widget then everything should work fine again at least that did it for me
I have not downloaded any widgets or changed any settings having to do iwth brightness. I downloaded a few games and I even uninstalled them to see if that would help but it didn't. I think my camera just may have some sort of defect.
thanks!!
