Help Camera LED notification
Cicliced
Hi,
When I receive an SMS msg it flashes the camera LED which is really bright and not very subtle when in public.
How do I turn it off? I can't see the option anywhere, either in the phone settings or app settings, I'm using Chomp SMS as default message app.
Thanks!
Never heard of the flash being triggered by chomp sms. There are 3rd party apps that do that, but not chomp.
Here is the answer:
Settings > My Device > Accessibility > Hearing > Flash Notification
Un-check Flash Notification.
Even if the flash notification box is not checked, check it once and un-check it again. It should solve your problem.
