Accessories camera lense replacement?
muddy00
Well I just realized my lenses over the camera is cracked. Not sure how this happens with a case on. Any idea where to get a replacement.
Mine scratched. I just took it off. The cover is worthless anyway. It seems to be more cosmetic than anything. At some point I plan on filing down the four plastic buds and making a flat cover. For now I have a metal ring glued to it for my macro lens.
If you really want to have it look stock you could probably cut out some plastic to replace the glass.
This is probably as close as your going to get for now:
HTC INCREDIBLE
It's silver and you have to buy the back cover along with it. May want to send them an email though and see if they have just the lens cover they can sell you.
