I'm Building a camera app and my Preview orientation is weird. I want it to be vertical but its showing landscape and its stretched out and skewed. I'm using a framelayout for the preview. http://i.stack.imgur.com/WNJUJ.png
MainActivity
CameraPreview
AndroidManifest
Activity_Main
MainActivity
Code:
import android.content.Context;
import android.content.pm.PackageManager;
import android.hardware.Camera;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.view.SurfaceView;
import android.view.WindowManager;
import android.widget.Button;
import android.widget.FrameLayout;
import android.widget.LinearLayout;
import android.widget.RelativeLayout;
import android.widget.Toast;
import java.io.File;
import java.text.SimpleDateFormat;
import java.util.Date;
import java.io.FileNotFoundException;
import java.io.FileOutputStream;
import java.io.IOException;
import android.hardware.Camera.PictureCallback;
import android.view.View;
import android.view.View.OnClickListener;
public class MainActivity extends AppCompatActivity {
private Camera mCamera;
private CameraPreview mPreview;
private Camera.PictureCallback mPicture;
private Button capture, switchCamera;
private Context myContext;
private FrameLayout cameraPreview;
private boolean cameraFront = false;
@Override
setContentView(R.layout.activity_main);
getWindow().addFlags(WindowManager.LayoutParams.FLAG_KEEP_SCREEN_ON);
myContext = this;
initialize();
private int findFrontFacingCamera() {
int cameraId = -1;
// Search for the front facing camera
int numberOfCameras = Camera.getNumberOfCameras();
for (int i = 0; i < numberOfCameras; i++) {
Camera.CameraInfo info = new Camera.CameraInfo();
Camera.getCameraInfo(i, info);
if (info.facing == Camera.CameraInfo.CAMERA_FACING_FRONT) {
cameraId = i;
cameraFront = true;
break;
return cameraId;
private int findBackFacingCamera() {
int cameraId = -1;
//Search for the back facing camera
//get the number of cameras
//for every camera check
if (info.facing == Camera.CameraInfo.CAMERA_FACING_BACK) {
cameraId = i;
break;
return cameraId;
public void onResume() {
super.onResume();
if (!hasCamera(myContext)) {
Toast toast = Toast.makeText(myContext, "Sorry, your phone does not have a camera!", Toast.LENGTH_LONG);
toast.show();
finish();
if (mCamera == null) {
//if the front facing camera does not exist
if (findFrontFacingCamera() < 0) {
Toast.makeText(this, "No front facing camera found.", Toast.LENGTH_LONG).show();
switchCamera.setVisibility(View.GONE);
mCamera = Camera.open(findBackFacingCamera());
mPicture = getPictureCallback();
mPreview.refreshCamera(mCamera);
public void initialize() {
mPreview = new CameraPreview(myContext, mCamera);
cameraPreview = (FrameLayout) findViewById(R.id.camera_preview);
cameraPreview.addView(mPreview);
capture = (Button) findViewById(R.id.button_capture);
capture.setOnClickListener(captrureListener);
switchCamera = (Button) findViewById(R.id.button_ChangeCamera);
switchCamera.setOnClickListener(switchCameraListener);
OnClickListener switchCameraListener = new OnClickListener() {
@Override
public void onClick(View v) {
int camerasNumber = Camera.getNumberOfCameras();
if (camerasNumber > 1) {
//release the old camera instance
//switch camera, from the front and the back and vice versa
releaseCamera();
chooseCamera();
} else {
Toast toast = Toast.makeText(myContext, "Sorry, your phone has only one camera!", Toast.LENGTH_LONG);
toast.show();
public void chooseCamera() {
//if the camera preview is the front
if (cameraFront) {
int cameraId = findBackFacingCamera();
if (cameraId >= 0) {
//open the backFacingCamera
//set a picture callback
//refresh the preview
mCamera = Camera.open(cameraId);
} else {
int cameraId = findFrontFacingCamera();
@Override
protected void onPause() {
super.onPause();
//when on Pause, release camera in order to be used from other applications
releaseCamera();
private boolean hasCamera(Context context) {
//check if the device has camera
if (context.getPackageManager().hasSystemFeature(PackageManager.FEATURE_CAMERA)) {
return true;
} else {
return false;
private PictureCallback getPictureCallback() {
PictureCallback picture = new PictureCallback() {
@Override
public void onPictureTaken(byte[] data, Camera camera) {
//make a new picture file
File pictureFile = getOutputMediaFile();
if (pictureFile == null) {
return;
try {
//write the file
FileOutputStream fos = new FileOutputStream(pictureFile);
fos.write(data);
fos.close();
Toast toast = Toast.makeText(myContext, "Picture saved: " + pictureFile.getName(), Toast.LENGTH_LONG);
toast.show();
} catch (FileNotFoundException e) {
} catch (IOException e) {
//refresh camera to continue preview
return picture;
OnClickListener captrureListener = new OnClickListener() {
@Override
mCamera.takePicture(null, null, mPicture);
//make picture and save to a folder
private static File getOutputMediaFile() {
//make a new file directory inside the "sdcard" folder
File mediaStorageDir = new File("/sdcard/", "JCG Camera");
//if this "JCGCamera folder does not exist
if (!mediaStorageDir.exists()) {
//if you cannot make this folder return
if (!mediaStorageDir.mkdirs()) {
return null;
//take the current timeStamp
String timeStamp = new SimpleDateFormat("yyyyMMdd_HHmmss").format(new Date());
File mediaFile;
//and make a media file:
mediaFile = new File(mediaStorageDir.getPath() + File.separator + "IMG_" + timeStamp + ".jpg");
return mediaFile;
private void releaseCamera() {
// stop and release camera
if (mCamera != null) {
mCamera.release();
mCamera = null;
CameraPreview
Code:
import android.util.Log;
import android.view.SurfaceHolder;
public class CameraPreview extends SurfaceView implements SurfaceHolder.Callback{
private SurfaceHolder mHolder;
public CameraPreview(Context context, Camera camera) {
super(context);
mCamera = camera;
mHolder = getHolder();
mHolder.addCallback(this);
// deprecated setting, but required on Android versions prior to 3.0
mHolder.setType(SurfaceHolder.SURFACE_TYPE_PUSH_BUFFERS);
public void surfaceCreated(SurfaceHolder holder) {
try {
// create the surface and start camera preview
mCamera.setPreviewDisplay(holder);
mCamera.startPreview();
Log.d(VIEW_LOG_TAG, "Error setting camera preview: " + e.getMessage());
public void refreshCamera(Camera camera) {
if (mHolder.getSurface() == null) {
// preview surface does not exist
return;
// stop preview before making changes
try {
mCamera.stopPreview();
} catch (Exception e) {
// ignore: tried to stop a non-existent preview
// set preview size and make any resize, rotate or
// reformatting changes here
// start preview with new settings
setCamera(camera);
try {
mCamera.setPreviewDisplay(mHolder);
Log.d(VIEW_LOG_TAG, "Error starting camera preview: " + e.getMessage());
public void surfaceChanged(SurfaceHolder holder, int format, int w, int h) {
// If your preview can change or rotate, take care of those events here.
// Make sure to stop the preview before resizing or reformatting it.
public void setCamera(Camera camera) {
//method to set a camera instance
mCamera = camera;
@Override
public void surfaceDestroyed(SurfaceHolder holder) {
// TODO Auto-generated method stub
// mCamera.release();
AndroidManifest
Code:
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
<uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE" />
<uses-permission android:name="android.permission.CAMERA" />
<uses-feature android:name="android.hardware.camera" />
<uses-feature android:name="android.hardware.camera.autofocus" />
<uses-feature android:name="android.hardware.camera.front" android:required="false" />
<application
android:allowBackup="true"
android:icon="@mipmap/ic_launcher"
android:label="@string/app_name"
android:supportsRtl="true"
android:theme="@style/AppTheme">
<activity android:name=".MainActivity"
android:screenOrientation="portrait">
<intent-filter>
<action android:name="android.intent.action.MAIN" />
<category android:name="android.intent.category.LAUNCHER" />
</intent-filter>
</activity>
</application>
</manifest>
Activity_Main
Code:
<?xml version="1.0" encoding="utf-8"?>
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:tools="http://schemas.android.com/tools"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
android:orientation="horizontal"
<FrameLayout
android:orientation="vertical"
android:id="@+id/camera_preview"
android:layout_height="match_parent"
<LinearLayout
android:id="@+id/buttonsLayout"
android:layout_height="wrap_content"
android:layout_gravity="center"
android:layout_alignBottom="@+id/camera_preview">
<Button
android:id="@+id/button_ChangeCamera"
android:layout_width="72dp"
android:text="Switch Camera"
<Button
android:id="@+id/button_capture"
android:layout_width="wrap_content"
android:text="Capture"
</LinearLayout>
</RelativeLayout>
