when i try to take pictures on the camera it comes up insert sd card before using camera! the sd card that came with the phone is in but says card is empty or unsuported filesystem! i have read there are problems with some sd cards so what type should i replace it with?
I had a Patriot Class 10 32 gb that couldn't go more than an hour after restarting or unmounting and remounting the card without having the pictures not save.
Now have a SanDisk Class 4 32 gb that had been fine for about 30 days and then last week started having the same problems.
Just wish Motorola would get their act together and fix this problem. I can't wait until ICS comes out to fix this.
I am pretty sure this phone has issues with class 10 cards because I also have this same exact issue but when I put in something with a lower class I can go months without having this issue.
