Root Camera problem!
nixxx0n
Today i tried to use my camera but black screen appeared, i restarted the phone and nothing. It worked for a few pictures after i took out the battery and restarted the phone. Now every time i want to take a picture i have to take out the battery and restart phone.It worked good for 2 months since i got it. So i wanted to ask you guys what would be the solution? I tried to install few ROMS (Zeus,DINC2HD,MIUI,Liquid,CM) camera works for 10 minutes or less and then black screen appears again.:(
My first suggestion to trouble shoot this is to nandroid restore your phone to a previous ROM/state. If this doesn't work, you can try deleting the camera app in /system/app and pasting a different copy of the camera app in the same location. You can do this by downloading a stock ROM, unpacking it, and navigating to /system/app. Then just move the camera app from your computer to your phone.
If neither of these things work, it is probably a hardware issue. You will need to call Verizon for this.
Let us know what happens.
Kratos
It looks like sd card was causing problems with camera,as soon as i remove sd card camera works when i put the card back it works for 10 minutes and stops :S (I tried 3 different cards). For the last one hour camera is working (i instaled Skyrider Zeus ROM) but don't know for how long. Is there some app to mount unmount sd card from home screen, i don't want to open case to take out sd card every time camera not working?
