I saw some comparison pictures between the Incredible and the Nexus One and was suspicious. (See The Incredible Camera Showdown: Droid Incredible VS Nexus One
Unless his wall is painted a blueish colorWow. Look at the fish tank pictures. In the Incredible the wall is white, other picture the wall is blueish. Same with the blankets on the couch. The couches are 2 totally different colars. IMO the Incredible wins.
Those coins definitely have motion blur with the Incredible or perhaps a problem with focus distance, but the dynamic range of the Incredible is definitely showing shadows and highlights with greater clarity than the other phone being compared.
I agree: The Incredible's camera design may have a higher minimum focusing distance and may thus require a little more distance between the camera lens and the object being photographed. Perhaps you could back both cameras up by a few inches and retake the "macro" test. I know this changes the parameters of your test, but we could at least then identify whether the issue is a minimum focusing distance or another matter--such as camera shake or sensor detail.![]()
