Help Camera Question
Is there a way to have some sort of steady option when taking a photo? I sometimes take a picture and my horrible steady hands make the picture a blur sometimes. If I concentrate and stay real still then the pics come out fine. I see there is an option for it when I'm taking movies but not for still shots. Thanks for your help.
I believe not. You do have "Video Stabilization" but, it is grayed out when selector is set to camera. It is for video only.
Find this under settings (the sprocket icon) when you touch the 3 vertical lines to bring out the options menu.
Camera Zoom FX app has the image stabilization feature....
Are you sure that image stabilization works with the Maxx.. I'm doubtful.
Let us know...
I've used it... waits for a period of stability before taking the shot. It also gives you feedback on how steady you are holding it... It is in the Market...
from the website
Awesome Shot Stability
No More Blurry Shots
Use the on screen Image Stabilizer to capture at just the right moment. The on-screen monitor will show you how steady you are holding your device.
[end quote]
I've had the same issues with stability.
Not to jack this thread, but is there a way to add a date stamp to the photos like the dinc could?
