Camera setting issue.
Hello everyone I'm new here so bare with me. I browsed the forums and didn't find the answer I was looking for... Here goes when I take a picture that picture is displayed on my camera screen and I have to push a button to take another. It seems that the settings haven't always been like this? I tried a few things to no avail.
I would like to be able to snap pics one after the next and have them go to my gallery instead of having to stop and push a button to activate the camera again. I'm not looking fo rapid shot or whatever just when I'm taking several pics at once I don't have to keep pushing that button in between. Thanks in advance I'm sure I'm missing something simple.
Once the camera is up, it should stay up on the screen.
Also, it should automatically store the pictures in the gallery w/o you having to acknowledge anything.
There is an option for you to review the picture, I have that feature turned off.
I suspect what you are experiencing is the "Review" option. To me, this only delays what I want to do. I turned it off.
Also, if you have Stabilization turned ON, that will delay the time it takes for picture capture. I turn that OFF also. Stabilization is great in low light, IF you have a tripod or something to hold the phone/camera steady long enough for it to take the shot.
The Settings window in the camera is on a Vertical Scroll. You might not be seeing all of the options available.
