Help Camera shutter sound...
cableguynoe
Android Expert
Not sure if this is a D2 thing only, but i cannot find where to turn off the shutter sound.
Stupid thing makes sounds even if the phone is on silent.
Am I missing a setting?
Mine makes no sound when the device is in silent mode.
The sound on the Omnia couldn't be turned off either unless the device was on silent.
There is a camera app that enhances the colors in pictures, it has an option to disable the shutter sound.
It's $3 in the market, Vignette.
OK, i figured out what I was doing. It's the focus button i guess.
If you hold down the button half way, it will beep twice, very loud! Even if it's on silent.
Seems kind of ridiculous to me.
I will try other camera apps to see if they can turn off all sounds.
if you had root you can just delete the sound the camera makes its a tiny sounds byte i saw it once take a look around if not ill find it for you later
It's because you need a root exploring app that allows you to mount the /system folder as RW (read and write). If you don't mount it as RW, you won't be able to edit/delete any files.
