Download and replace your camera app with that one, in the /system/app directory via a root-permissions file explorer (like Total Commander or Root Explorer).
Reboot, and you should be bueno.
2. With a root permissions file explorer (examples above), navigate to the /system/media/audio/ui directory, and move (cut) the files from that directory and move them to another directory that is not under /system, then delete those audio files. You do not necessarily have to move them, but renaming them doesn't work so deletion (or replacement with same-named files but ones that contain no sound, should work as well).
3. What works 100% chance: Do both 1 and 2 from above, and you're golden.
