Iconoclast
I had set it to store in the large 32 GB SD card soon after I got the phone & as recently as August had taken some photos & they were there as expected. Today I took 4 photos & they appeared as expected in my gallery but when I attempted to transfer to my computer via USB, they were not in the SD card DCIM/Camera folder with all the other photos! I finally found them in the Internal Storage/DCIM/Camera folder.
Anyone else have their storage location mysteriously changed?
Here is how to manually move the files from Int. Storage to Ext. Storage SD card & then switch the storage location back to SD card.
To move files between internal and external storage:
. Open the applications menu.
. Scroll to and tap My Files to open the file manager
. Tap Internal phone storage
. Scroll to the folder or file location to your desired file
. Tap and hold the file, then choose Copy or Move
. Press the back key and Tap the SD card
. Scroll to the folder or file location where you want to place your desired file
. Tap Move
. Your file has been placed into your other storage location
How to change camera storage location:
Open Camera
Menu
Menu bar should roll out
Tap the sprocket icon
Scroll to Storage Location
Tap it & select SD card & not Internal Storage
. Tap Move
Open Camera
Menu
