Myles Jarman
Hi all,
I know this is a common fault, but I'm seriously at my wits end.
Today I went to take a picture of my friends new car to show someone, and the camera app crashed and the message "Camera has stopped working" was displayed. I found that strange, and so looked into it.
It appears that Last Pass is a major contributor when it comes to this problem, but I don't have this installed.
I then had the "gapps" process error where the error message repeatedly came up on screen to the point where the phone was rendered unusable and I ended up factory resetting the phone.
Fresh from a factory reset, the "gapps" error is gone, however I'm back at square one with my camera not working. It was working fine when it dropped out my pocket getting out the car, cracking the screen. It was also fine when I dropped a dumbbell on it last night as i took some pictures of my girlfriends cat after doing so and it all worked perfectly.
I havent installed any new apps between now and then, I'm running a completely stock phone, and I have uninstalled the Google Applications Service app or whatever it was called. Ive cleared the Cache and the data on the camera app, again, I dont have lastpass installed, and I'm currently losing my patience rather rapidly
Any suggestions will be greatly appreciated, as I'm just using this to get me through to Project Ara's release and then this can take a long nap in my little box of spares just in case.
Thanks,
Myles.
Thanks,
Myles.
Yes, took me about 30-40 minutes to strip down (it's not as big of a task as it sounds really) and then half that to reassemble it. Most of the time i spent making sure if i moved something, it didn't break something else.
