REALOldNick
Member
I am not sure if this started with Android 4.2.2.
I tried to read a barcode that my wife's Galaxy Note 8 was OK with, in the same app I am using. I tried many distances , from near to 1+ m, but it just could not read the barcode. It was too blurry to read for sure.
Does anyone know about this and maybe hoew to fix it? (PLEEEEASE don't tell me a I need to root the machine. IT works, the instructions I saw were insufficient to my feeling, in that I was told to install and app, then go Settings ..whatever, and there _were_ no settings ----whatever on the Android. Did they mean in the installed app? etc. Quite often done by people who -really_ know what they are doing, but forget that not everybody does. This was common the several instructions I read. So if you kn ow a "rooting for dummies" (And remember the term is not mine) then I will keep looking....if necessary. I am/was pretty good at Windows, but I just want to use this machine.
Thanks for any help
Nick
Thanks for any help
Nick
