Help CamScanner Pro Apk for Android - How to install?
Hello friends
The phone that I use is Redmi 7 pro and currently I am facing problems when analyzing the package after the download of CamScanner Pro Apk app is complete, it says "Problems analyzing packages, app not installed"
Is there a way to fix it? Please help, thanks everyone
are you sure the error says "analyzing" and not "parsing"? analyzing usually has to do with the app not being compatible with your device. if it is parsing, then there is an issue with the apk file itself....most likely a bad download or a bad file.
