Denis.Beurive
Hello,
I am fairly new in the Androïd's world.
I've seen that it is possible to turn an Androïd mobile phone into a WIFI access point. This is done through the general configuration interface of the phone. But I am wondering:
Is to possible to turn an Androïd mobile phone into a WIFI access point programmatically?
Note that by using the term "programmatically", I mean: "by an application". In other words: Does an application have access to the configuration that is used to turn the phone into a WIFI access point?
Assuming that the application has turned the phone into a WIFI access point, can it bind a socket (or whatever is the Androïd equivalent of a socket) to the WIFI interface and start acting as a server?
In short: can an application turn an Androïd device into a WIFI access point and then act as a server listing to, and answering from, the WIFI interface?
If the response is "no, it can not", then I assume that it is a restriction from Google.
Thanks to everyone,
Denis
Thanks to everyone,
Denis
It is too easy to hide
