DaisFlaque
Android Expert
Extracting the ROM and packages
Once you have the ROM you'll need to extract it so you can work with the correct packages. I used a zip file extractor to extract the ROM and also to extract the com.htc.resources.apk and framework-res.apk packages which are located inside this ROM.
This is a post from the theme guide, I put this exact method to use and nothing, I did it with out the extra zip, and got somewhere.
I am running windows XP sp3, It's a Dell Dimension 1100, home edition. Have done everything like rooting or setting up ADB with SDK, wireless control and lots of other stuff.
Here's the weird part... I downloaded the apktools zip and unziped the folder and its a java run time thing. Any ways nothing happens. so I got apk Multi-tools from this guide and it tells me no adb?? press any button to continue...
Yeah I go along with the prosess and hit 25, then 1 (where I put SystemUI). Then 9, and it put the files there like it said. I then minimize/close (done this several times now), like it said i put them back RIGHT were the were... Hit 11 for COMPILE and WHAM!!! NOPE!! lol it says its never been extracted and it needs to be (nope tried this too) and will not go anywhere from here. tried to manually zip it back but nope...
Any help would be awesome (for the whole community I think)...
