teddytales66
Member
I flashed the cm10 mms fix right after installing the gapps but my mms still doesnt work & i get mms force close
can anyone help me fix this?
What hboot and what recovery are you using?
I think you have to delete the mms.apk that was in the phone with root explorer, then you can flash the fix. That's what I've done and it's worked for me.
Weird... Try re downloading the Sprint version. Then flash the Virgin mms fix . Actually tried re downloading them both over wifi then make sure you wipe everything then wipe dalvik as well then flash and make sure smart flash is disabled
I am guessing you flashed the CM10 MMS fix instead of the CM10.1 MMS fix. Flashing the correct file after a full wipe and install of the Sprint version should take care of your issue.
CM10.1 MMS Fix+Cache
