Root Can Anyone Help Please... Boot Loop Samsung BH2
penerk11
Can someone please help me...After trying several ROMS over the past week I installed BH_Man R11 using the ODIN method (as I did with the other Roms) For some reason it will boot loop and then turn off and not restart without pulling the battery and manually restarting. It will not get past the boot screen. What did I do and how can I fix it? I appreciate any help you can give.
You have done something to the system, you will need to install another (or the same, but not the rom that ruined the phone) ROM on the SD card.
