hi,
my system has 1GB system drive. and internal 5GB nand flash drive.
the base system itself is over 800MB already, that leaves me a little over 100MB for any app i want.
when i try to install, i would get the message
"insufficient storage available"
it appears that when installation always uses the system drive (i'm correct?)
i've tried recommendations to clear cache, move apps to SD (but you cannot move everything)
i want to install bigger apps, but my storage is limiting me. is there anyway i can install directly to the other drive?
desperately yours,
joey
android 4.2.2
TIA!
desperately yours,
joey
android 4.2.2
TIA!
