With Virgin Mobiles Plan for this phone you can only purchase money cards. You add this money to your VM account. If you run out of minutes it will charge your account. The only other option is to do the full monthly pay when you run out. You new monthly minutes will start on that date,and end on that date a month from that point.I've been talking a lot on the phone recently and I currently have 197 minutes left for the month so I was wondering if buying a 100 minute card will actually add 100 mins to my 197 or will it stay at 100?
I went to Walgreen's and bought a $10 Top Up card. That added 100 mins and was added to my account right away.I've been talking a lot on the phone recently and I currently have 197 minutes left for the month so I was wondering if buying a 100 minute card will actually add 100 mins to my 197 or will it stay at 100?
I forgot that VM raised the cost of the V's cheapest plan to $35.00. If this can be done in the fashion you described then it would be the cheapest way to go for sure.I went to Walgreen's and bought a $10 Top Up card. That added 100 mins and was added to my account right away.
You just "Topped Up" using the $10.00 card and then what did you select or do after that to get it to add the 100 minutes right to the monthly minutes.
Duh! My old brain is getting slow. 10c a minute x 100 minutes = $10.00You don't have to do anything - you run out of minutes, so they start charging you $0.10/minute, which is deducted from your balance.
Yeah, if you have a balance. I don't have a CC on file with VM after reading some unsavory reviews regarding lost/misplaced payments.You don't have to do anything - you run out of minutes, so they start charging you $0.10/minute, which is deducted from your balance.
