Can i connect a controller
miskas
Member
Hi is there a way i can buy an adapter to connect to the proprietary cable and then connect it to my controller and would it work?
A playstation 3 controller will work if you have a dock via the USB cable. Supposedly it will pair up with the bluetooth as well. However if you turn off bluetooth or want to turn the controller off it will blink away till it either times out or the battery dies.
If you ROOT your tablet then you can use this tool here:
Dancing Pixel Studios to assign your tablets bluetooth mac address to your controller.
You also need the app from the market:
https://play.google.com/store/apps/...Rpb3Muc2l4YXhpc2NvbXBhdGliaWxpdHljaGVja2VyIl0.
It's $2.oo and worth every penny. when you turn off the app it turns off your controller plus lets you map your buttons real easy as well.
